Publisher: Ubisoft
Far Cry 2 is the latest first person shooter from Ubisoft and it's one of the most hotly-anticipated games of this year. While it continues the
Far Cry franchise that Crytek started in 2004,
Far Cry 2 is built on its own in-house engine and has no association to anything Crytek has worked on or is working on now.
The game
uses DirectX 10.1 to improve anti-aliasing performance and quality. The improvements are made by reading the multisampled depth buffer in a single pass - something that was only introduced officially with DirectX 10.1. However, Ubisoft has also made the enhancements available to Nvidia hardware as well through a DirectX 10 extension.
We used the game's built-in benchmarking tool to measure performance in DirectX 10/10.1 mode - this provided a pretty accurate rundown of how various graphics cards perform and it shows off a lot of the game's special effects. We set every option to its maximum setting and tested at 1,680 x 1,050, 1,920 x 1,200 and 2,560 x 1,600 with various anti-aliasing settings.
Anisotropic filtering is controlled by the game's quality settings and forcing AF from the driver control panel does not have any effect on visual quality or performance.
ATI Radeon HD 4870 X2 2GB
Nvidia GeForce GTX 280 1GB SLI
ATI Radeon HD 4870 1GB CrossFire
Nvidia GeForce GTX 260-216 896MB SLI
Nvidia GeForce GTX 295 1,792MB
Zotac GeForce GTX 285 1GB AMP!
Nvidia GeForce GTX 285 1GB
ATI Radeon HD 4870 512MB
Frames Per Second
20
30
40
50
60
70
80
90
Frames Per Second
20
30
40
50
60
70
80
90
Frames Per Second
20
30
40
50
60
70
80
Frames Per Second
Frames Per Second
Frames Per Second
Frames Per Second
Nvidia's GeForce GTX 285 is around five to ten percent faster than the GeForce GTX 280 in
Far Cry 2, depending on the resolution and anti-aliasing settings. Zotac's AMP! Edition card edges ahead by a few more frames per second too, but the advantage isn't quite as clear between itself and the stock 285 as the gap is between the reference 285 and 280.
